SilversunMSP
I saw this on TV so I thought I'd give it a try. It actually worked out very well so I thought I'd share the results. Here's the before and after on my wife's Hyundia Santa Fe.
All you need to get these results are:
1500 grit sandpaper
water in a spray bottle
Rubbing compound or even regular toothpaste (I used rubbing compound)
An electric buffer or some manual elbow grease
Directions:
Wetsand the headlight making sure you keep the area coated with water. No need to apply alot of pressure, you only need to remove a thin layer of oxidation from the plastic headlight. This step should only take a few seconds.
Next, apply a few dabs of rubbing compund and use a buffer over the surface of the headlight. Be sure to buff all areas evenly and be careful not to overdo the edges.
Rise off the headlights with water and wipe them with a lint free rag and that's it. New looking headlights without the cost and hassle of replacing them.
1500 grit sandpaper
Directions:
