is that calibration in the transmission or the gauge cluster?
well it wouldn't be in the trans, as the ABS cars read speedo off of the wheel speed sensors (I believe?).. but i don't know if its in the ECU or the cluster. do the non-abs cars have a mechanical VSS or electrical?
its not the ecu, because my speed sensor goes right from the trans to the gauge cluster. i had a msp gauge cluster at one point and didnt notice a difference (dunno)
Finally got my BPV, that only took 3 weeks.
I'll most likly have to weld on a tap on my cold pipe someplace right? I have the nipple that use to go the VC but thats a bit smaller than the BPV size.
Could I use it or will I have to weld?
