xDJ DUBx's 03.5 Pure White LX-T
Esh. This usually happens on upgraded setups though right, like bigger boost/turbos, not really the stock gt25r?
Ya know, I'm not 100 percent sure actually. ahtere are plenty of theories out there. But I'm not sure.
dub can you post some hi res shots if you got them?? im trying to make a t-shirt. but nobody has high enough res.
basically, fuel cut feels like suddenly when you were accelerating, all the fuel stopped being delivered to the engine... weird, I know!
as for fixing.. clear your vac leaks, turn down your boost, get a (better) tune, upgrade your injectors. in that order.
How do you know if you have vac leaks? Everything sounds/seems sealed.
I can't turn the boost down, seeing as I never turned it up.
Looks like this will be hanging around for awhile. Another pleasant side effect of the protege.
