winter tires?
legojo
mazda cx9
Hi, just need a little help...Is anyone using 245/65/17 winter tires on 17x6.5 steel rims? will they fit ok on the cx9? thanks in advance.
Hi Bajan Loch,
Is there sufficient clearance for the disc brake rotors and calipers using the 17 wheels? Thanks in advance.
There is clearance with 17" wheels. I had this confirmed with Custom Wheel Outlet. I am not sure if this goes for all setups though.
as long as the wheels have the proper offset to clear the brakes it will work fine.
Looking to get 245/65R17 for winter. What offset is needed for the wheels? I wanna make sure I don't end up with a set of wheels that doesn't clear the calipers on a 2011 CX-9 GT.
