Winter tire
kk52736
2003.5 Mazda Protege 5
I am ready to shop for some winter tire for my P5, but is it nessesory to put winter tire on this car? if it is what kind is good on price and quality? where to get the steelie wheel too?
Get some steel rims and winters ASAP! You'll be cursing yourself if you don't. First off, these "all season" tires perform bad in the wet, so you can imagine how they they'll react in snow/ice.
Also, I'm not exactly sure where in Alberta you are, and if they use salt on your roads, but if you keep the stock rims on, the salt's gonna **** the rims. It happened to mine, and I even made sure to wash them every week or so.
If you plan on keeping this car for a few years, then get out there and pick some up.
I can't recommend any specific brand, but I got a good deal on a set of 14" Goodyear Ultra Grip Ice. They weren't my 1st choice, but they work well. Look into getting some Nokian Hakkapelitta's that can be studded. It's illegal in Ontario, so I decided not to get them, but I think in Alberta it's ok.
Good Luck
-Erik
it's not absolutely necessary to get winter tires for our cars. i used my stock wheels/tires last winter, and i plan to use them again this winter. if you get a lot of snow, you may not want to, because when the snow is fairly deep the tires don't work all that well. erikvonb is right about the wheels getting damaged from the road salt though...if you're concerned about that, get steelies.
so is 14" rim good for P5? and i am in calgary, and i think the stock wheel are too slippery on snow, and i already slip off a curb and got a scratch on my stock rim, lucky at a low speed.
we get a lot of snow here in calgary, so i think i better go with steelie and winter tire, and i had check with mazda dealership, they are selling $739 with steelie and Hankook winter tire for lifetime tire switching...
what do you mean by lifetime tire switching....they will put on and take off your snow tires for you every year, or what? you should also check out canadian tire, they usually have good deals on winter wheel/tire packages.
if i go check out in canadian tire, what size of wheel should i look at and what kind of winter tire is good, i know nothing about winter tire...
if you want 14", go with 185/65/14.
if you want 25", go with 195/55/15.
(it's all in the manual by the way)
I recommend 14", especially if you get a lot of snow.
I think the only tire worth getting at Crappy Tire is the Michelin Artic Alpin, but that is up for debate. anyone else?
-Erik
well i'm not using my P5 this winter.. but i have a nordic winter tires on my civic it works good.. cost me $180 for 4 but its 13" though
so is that Artic Alpine is good enough for heavy snow?? up hills and down hills too?
I would go for the Nokians if I were you if you have heavy snow. The studs will make a huse difference. Or you can go with Bridgestone Blizzaks (studless), but apparently vey good in snow.
Artic Alpins are supposed to be better on ice.
By the way, I would definitely go with 14" tires & rims.
-Erik
I went through last winter with my stock rims and tires, and found them acceptable (better than the previous car I had, at any rate). However, because of the extra wear on both rims and tires - and the expense required to replace them sooner - I decided to get steelies and winter tires for this season. (Of course, just when I have to sell my car :( ...)
After driving around with the new set up for about a week now in the snow, I have to say that I love them! I got the 15" steelies for the Protege from the dealership where I got my car (great price - $200 for the 4), and I decided to go with the Nokian Hakkapelittas (195/60R15). I've got great traction, and I really feel that the tires are gripping the road. Because of the slightly higher profile than the stock tires, I don't have any clearance issues, and the car still handles great - not that I'll be doing any 60 kph corners in the snow (at least intentionally! :D ). I know a number of people here in the Edmonton group have the Arctic or Pilot Alpins, and are happy with them. I personally would recommend staying away from the blizzaks - they're just too finicky.
Changing the tire diameter will CHANGE the vehicle speed for the same motor RPM!
This ALTERNATE tire size will change the actual vehicle speed to
mph, when the odometer reads exactly 65mph.
sorry
here
This ALTERNATE tire size will change the actual vehicle speed to 65.07
It's interesting that others have no problems with the stock tires on our P5s in winter while myself and many others think they are crap in winter.
Last winter I put on 15" steel rims with Michelin Pilot Alpins and the improvement was amazing. Never got stuck once and I always felt I was in control even with the roads pretty bad with snow and slush. Like MyZmZm, I bought mine from the dealer for $50 each and the tires I got from Costco but Canadian Tire has the Artic Alpins on sale I think.
