will a 17x7.5 fit...
SurlySays
2011 Mazda2 Touring
will a 17x7.5 fit on a Mz2 with no rubbing or modding on stock suspension... and will it still fit once i get some aftermarket suspension?? rim measurements are 17x7.5 4x100 42mm offset! thanks guys
Depends if your lowered a 205 40 fits no problem if ur not going lowered then you can wide it out to a 215 40 -45 its up to u on how thick you want the tire.
used that before with 205/40/17 tires. dropped on eibach springs. didnt experience any rubbing even on dips and bumps
