Who is using a J-spec cam?
The cams are just from the 170hp FS-ZE engine found in Sport20s. The FSZE has higher compression, diff intake manifold, and fuel/ignition map to optimize the total package. Just get blank cams and grind them to turbo specs.
well, a couple of days ago my engine rebuild finally
came to a close. im still breaking in the new motor...
thats going to be a slightly long project itself...but
so far everything seems great. my turbo spools so much
sooner now (2K rpms). the new cams prolly help with that and even
driving soft, you can feel the difference in pull throughout
the entire rpm range. i think the mazdaspeed cams are great!
it ran rough at first though. prolly two things...bad gas at first and then
the ecu readjusting. other than that, so far so good.
