Who is switching to winter tires and steel wheels?
Anyone use 16" winters on their CX-5? I use 16"winter tires on my Mazda 6 that has 19" tires and wondered if I can use them on the CX-5 Carbon with 19's.
From what I've seen a 16" SHOULD fit a non turbo, but won't clear turbo brakes. Very little clearance though. If you can test fit them and you're happy with the clearance and they have the same outside diameter I don't see why it wouldn't work though.
Got a new set of Blizzak DMV2 tires on cheap 17” alloy wheels on the other day. The CX-5 is an absolute beast in the snow.
I have found that my local Firestone likes to deal if you tell them about online prices.
nice, i had good luck with sams for my old pilot-the guy there knew something about tires-was eating tires and had been thru a few sets 20k...he took out a little book checked a few things on the pilot and got me some pirelli a/s but sized up the load range-problem solved 60k later went rite back for a visit-oem discount,no charge to install so less $180
Any info on wheels for the CX-5 - specifically width-stock seems to be 7" but I see 7.5" will work...Confused.
Tire Rack is very conservative with their fitments, and they'll sell you wheels as wide as 9.5" for a CX-5. It depends on offset and rim diameter, with smaller wheels being limited to narrower widths. In 17" sizes, the widest wheel they have is only 8".
No problems with wheels 9" wide at stock +45 offset, just don't put fat tires on them.
Would you know if the wheel size you have is 7 or 7.5"? Thanks
Not sure. Bought the wheels and snows at Discount Tire and they verified fitment. Probably whatever wheel width was standard for a 17” rim on a 16.5 CX-5.
