Who is switching to winter tires and steel wheels?
Anyone use 16" winters on their CX-5? I use 16"winter tires on my Mazda 6 that has 19" tires and wondered if I can use them on the CX-5 Carbon with 19's.
From what I've seen a 16" SHOULD fit a non turbo, but won't clear turbo brakes. Very little clearance though. If you can test fit them and you're happy with the clearance and they have the same outside diameter I don't see why it wouldn't work though.
Got a new set of Blizzak DMV2 tires on cheap 17” alloy wheels on the other day. The CX-5 is an absolute beast in the snow.
I have found that my local Firestone likes to deal if you tell them about online prices.
nice, i had good luck with sams for my old pilot-the guy there knew something about tires-was eating tires and had been thru a few sets 20k...he took out a little book checked a few things on the pilot and got me some pirelli a/s but sized up the load range-problem solved 60k later went rite back for a visit-oem discount,no charge to install so less $180
Any info on wheels for the CX-5 - specifically width-stock seems to be 7" but I see 7.5" will work...Confused.
Tire Rack is very conservative with their fitments, and they'll sell you wheels as wide as 9.5" for a CX-5. It depends on offset and rim diameter, with smaller wheels being limited to narrower widths. In 17" sizes, the widest wheel they have is only 8".
