I am a bad person. 2018 CX-9, nearing 160,000 km. Never had new transmission fluid. Never had rear wheel AWD “differential” fluid changed. Am I in “now or never” territory? I’ve read doing it/them at higher mileage is inviting problems. Should I leave well enough alone?My 2022 CX-9 has 55k miles. Seems like I should do a transmission fluid change. Who did it and how many quarts of new fluid did you need? Did you just drain the fluid or also change the filter? I don’t think Mazda makes a new pan gasket so do you make one of your own?
Edit: Too late i'm afraid for trans fluid. Change only diff and transfer fluid at this mileage or you are ASKING for trouble.I am a bad person. 2018 CX-9, nearing 160,000 km. Never had new transmission fluid. Never had rear wheel AWD “differential” fluid changed. Am I in “now or never” territory? I’ve read doing it/them at higher mileage is inviting problems. Should I leave well enough alone?
Thanks for replies folks.I would change the transfer case and rear diff fluid. Just a simple drain and fill.
Transmission fluid is a bit more complicated, and I'm hesitant to recommend anything. Personally I would just do a drain and fill if the transmission is shifting well with no issues. It might be best so speak with a local transmission service shop to see if they have any experience or recommendations for your car at that mileage.
160,000KM - Too late i'm afraid. (To change transmission fluid)
Differential and transfer case fluid only at this point in time. If you try and change the transmission fluid at high mileage, you WILL have slipping problems and way more headache than you bargained for. The previous poster who said nonsense, well that is their own lesson to be learned.
Slightly off topic (and tech is not what it is today), but my parents had a 1991 Ford Taurus that I took over when I got my license and the transmission went at just under 200k km. Fluid was never replaced prior to the failure.Nevertheless, our Skyactive powertrains were built to last!
A good friend has a Ford Taurus at 90k miles and refuses to change the transmission fluid even though it's acting up, and he's on his 3rd transmission already. He puts Lucas in to his tranny and it's been making a gradual improvement.
