Which sway bar bushings?
Our front is a 25mm correct?
The link is to a 23mm bar kit. Doing some research some people said they had to mod the mounting bracket to use the enegry suspension ones. Anyone else have this issue? Anyone have a direct link to the ones that fit the racing beat 25mm bar or even a part number?
The link in the original post was for "street unit" bushings. Anyone have these?
Thanks guys
yes the energy ones are pretty thick they come with there own bracket but you have to bend it to fit but at least it has zerks so you can grease them up.
I bought generic energy suspension 25mm bushings with brackets and tried to install them before and over all just seemed so much bigger, and would not fit...is there another 25mm set or is that the only one?
i dont know or remember i do know they where thick and just made it work..sorry for the no help..
