Where to mount HID Ballast's?
I stuck one to the fuse box and the other to the PS fender. They have come off a few times so I plan on mounting them behind the bumper this Spring.
I mounted mine behind the bumper. The driver side has a nice empty bracket perfect for zip-tie'ing the ballast to. The passenger side is a big more difficult because of the stupid placement of the windshield washer reservoir, but you can find a good spot there
I remember I mounted mine near the coolant box and the other one just tied firm with the other hoses.
Mounted once at the lower bump, water went in and screwed. Make sure the place you mount at is safe from water.
if you want a clean (but more lengthy) install, there is a spot for them behind the quarter panel (can't see them from the engine bay.
