- 2001 Mazda MP3
so yeah, any one here changed their oil... mine has 3000 miles and need to do it... or is their a how to on here anywhere
Do a search in the how-two section, it's there.so yeah, any one here changed their oil... mine has 3000 miles and need to do it... or is their a how to on here anywhere
Amazing... in the How-To forum, there's a How-To titled HOW TO: Change your own oil. Thanks, never would've made that connection on my own.
Try your owner's manual. Or just crawling under and taking a look.
ProTip: It's not a conventional screw-on filter.
yes i see that, but the pictures nor the description don''t show or tell where on the block is the filter
thanks for the "kind" help guys everyone knows the search engine on this forum is a waste
under the car, front of the engine block, middle of that. black cap with an allen head drain plug in it. the drain plug is straight back from that. oil fill plug is that big red piece of bling under the hood on the pasangers side of the engine it says mazdaspeed on it. oil goes in there 6 qts to be exact. and then on the front of the block middle of it there is this yellow ring thats attached to the dip stick. you have to pull it out cleer it of oil then reinsert all the way then when you pull it out the second time it will read correctly.
you have to pull it out cleer it of then reinsert all the way then when you pull it out the second time it will read correctly.
