Where is Everyone Mounting stuff?
I don't remember if I posted this pic already, but anyhow
here's my Greddy Turbo Timer. This is my first time with a
Turbo car & a Turbo Timer, so I put it right in front of me
so I can see it everytime I drive.....:D
i dont have pics...cuz i havent mounted anything yet...but im going to put a turbo timer, probably same place as AGR#7 and im going to put a litte LCD display in the pocket underneath the CD player hooked up to the on board diagnostics...its gonna be tight lookin, ill post pics when i get all done :)
If you are referring to mine, they are all Auto Meter Pro Comp Ultra-Lite gauges (A/F, Boost and Oil Pressure).
i installed my own turbo timer and it really wasnt that hard. ummm, as for everything else, ill be posting pics up as soon as i get my car back and everything in. should be within the week but thats how long i take to install the stuff. ill let you see later
HAHA cheap bracket. Thats an Autometer 2 5/8 Gauge pod not just a ring. Have you seen the greddy ones? they look about the same and they r like 60 or 70 a piece. I didnt really feel like taking out the a pillar and pushing it all behind it (all ready did that ones for the radar detector). So what u got?????? hummm oh yeah so who makes those 60mm gauge pods for our cars again????
my stuff
these were taken at night sorry for the poor lighting. i made this pillar out of a factory pillar with some bondo/fiberglass and vinyl it holds a blitz 60mm boost gauge
Ummm, from what i can tell it's cool...I like the gauge fo' sho'...Do you have any pics of it in the light??? I want to see the quality of the molding job.
il ltake some more tomorrow in the daytime here is another closer one. also how the hell do you post multiple pics on one thread with out multi posting? im a newb
Are there many boost gauges available in PSI??? I thought most of them came in BAR due to the fact that one gauge has such a wide range of pressures...you know, to go from 0-?? PSI. Think about how small the numbers would be for a gauge to go from 0-30 PSI versus a BAR gauge going from 0-2 . I guess it's preference...
im used to bar had it in my eclipse and in my 200sx 1bar=14.7 psi our cars from the factory boost just under the .5 mark about 6.5 psi ish
I installed my timer too only thing that got me was making a bypass for the factory alarm. well I figured it out now anyone else had that problem? and for the guage pods all you do is take a existing pod holder say from auto meter in the size you want, take the a pillar panel off use some fiberglas and resin and then mold it on...its easy to make if you have done body work before...
Mods:
HKS Type 1 US Spec
Mesh Filter just put on not much difference...sucking in hot air from the radiator...just makes the stock diverter valve sound like the predator
In process
HKS titanium blaze custom 3 inch mandrel turbo back, d-pipe and test pipe for race use...might use a random tech high flow cat.
And maybe Injen Cold Air Intake unless when upgrading to a larger front mount the I/C piping might run thru the same hole the intake is goin into...im not into cuttin up the radiator support... maybe trimming the bumper support... anyone try this yet?
The only thing I've ever fiberglassed is the front bumper on my Civic...That wasn't too bad, but im not touching the inside of a $20,000 Mazdaspeed. I've got a few tricks up my sleeve, but I need my MSP back to try it...it's driving me crazy not being able to run out to the garage to check something out...
dude i know! i want to run out and check the depth of the groove of the "Mazdaspeed" engraving on the front door scuff plates. it would be badass to put some white EL wire in there, provided the depth is deep enough.
