depends how far you want to get into it. and how many different suspension components you want to add. theres to many parts that make up the suspension to say what one part will be the best for a certain setup so how far did u want to go??
well a good set of coilovers, fix the sway bar clunk problems, good brakes, and tires.. a good alignment will help with autocross.. and put poly bushings instead of the stock rubber.. but when u do make sure to grease them good or it will squeek.. that should help a lot on the track i autocross and drag my msp and it does great with the stock setup i got... i have great tires though... im running the dunlop direzza sport z1 from tire rack!!! i would recommend them to anyone looking for an incredible tire!!! great in the wet and even better on dry ground.. i drag raced all last year and started autocross this season with them and they have good tread left still and handle great.. they heat up and get really sticky... sorry for going off about tires.. lol i love them though..
the thing that will increase handling by far is a good set of tires. i do have to say dont just order a bunch of suspension stuff and expect it to work well together though. go out to the track with your car how it is now. find out what you want to change and order one part. put that on and see how it changes handling and how it reacts with other suspension components.
