whats next
cams when someone(not a dealership teckie) figures out the timing of the timing chain :(
What? There are tools you can get that will make it an easy install. There is nothing to figure out!
so just the tools and anyone can do this?
Yes there are tools to keep the timing in place, there will even be tools that will let you adjust the cam gears without adjustable ones. It is not as hard as some have made it out to be.
go for a turbo...this is the best way if you want power, without doing dammages at your compoments. You could run @8 psi and get aroud 220-240 hp and you would have plenty of fun... (dance)
I'm on engine 2..no turbo kits for me...
Az have you removed the balance shafts yet?
