yeah sounds like the heat shield or you no longer have a flex pipe and having that long of a stright pipe with no flex is going to cause some noise when the engine moves... have you upgraded your motor mount yet? i don't have a flex pipe though i do have a stiffer motor mount and it isn't bad except at initial start up and accel after that it pretty much goes away 90% of the time.
