So you just ran it through the valvetrain? Are you going to change your oil soon or is that just when you use it in your oil?i just got done seafoaming. put about a 1/3 into through the brake booster line.
CEL didnt even come on. tons of smoke came out tho. it seems to be alot smoother. now im just waiting for the fedex guy to bring my coil packs.
ordered a set of Posi Quiet pads for all 4 corners.
Remember pointing them a bit lower than stock to reduce glare on incoming drivers.![]()
sounds like egr + something. or maybe intake is loose on throttle body?Well she's been having some problems today. I've gotten a strange rattling noise on three different occasions and I can't figure out if it's just a pipe rattling against something else or if it's something more serious. To check, I revved her up to redline a few times in the parking. Well apparently she didn't like that because on the last rev she almost stalled coming back down - the RPM kept fluctuating between about 1000 and zero. I've also had this sort of thing happen on cold starts occasionally - would go from 2000 to almost stall to 1500 to almost stall and eventually it would clear up. Anyone know what this sounds like?
Sounds like you blew the welds on the intake....
Which years had the EGR problems? I thought '02s didn't have that problem - or is that the VICS butterfly problem? Man, I can't remember anymore. She's driving better today but I'm going to go out and check some things anyway. I'll probably clean out the EGR and seafoam the top end next week as well.sounds like egr + something. or maybe intake is loose on throttle body?
DANGER TO MANIFOLD! (ricer)Sounds like you blew the welds on the intake....
