Ask yo momma2 trains enter a tunnel. What time does train A reach Perkipsie.
Its Micheal paler with his face in a pie times Douglas Adam square.
But I don't know, thats just what a ninja told me once
So the Racing Beat swaybar has shorter ends than the stock bar? I have both my Progress and stock swaybars sitting here in front of me and they are identical sans thickness. So crap, did I make a mistake ordering the AWR endlinks? I'm beginning to wonder now what the ideal setup would be then? I suppose I could always just make the AWR endlinks the same length as the stockers and reinstall. I mean the stocker never bent/broke and they have been through a lot but then again they also weren't attached to a 22 mm thick swaybar! Anyone have a decent picture of the stock swaybar/endlink setup? I only have a single half-assed pic from when I was removing it.wow! I must apologize, as I had no idea that the progress bars ends were that much longer than the RB. I really feel bad about this man. The RB one seems to be ok this way, but yea it is quite obvious this is not true with your progress bar. Well, try to put it back the way it was with the end links relaxed as possible and you should be ok. Again apologies for the confusion.
Well the Progress bar is the EXACT same design as stock but just a thicker bar (22 mm as opposed to whatever stock is - 16 mm?). You have the Racing Beat bar off the Mazdaspeed Proteges I assume? Didn't those cars also come with shorter rear endlinks? If so, I now know and can see why. Well I guess I'll just have to wait until my endlinks come in and I'll play around with them then. Mazdaspeed777, let me know if you make any headway!this is very strange....have a look at this pic....see how the end link is on the inside of the lateral link? I really have no idea why the progress bar positions the end link on the outside of the bar. (dunno)
I really dont know what to say about all this...(dunno)
oh, and no you didnt make mistake in ordering the end links magnum. You will just have to play around with them and see what works best for your application.
You have a P5 right? You haven't changed the rear subframe or anything?again, strange... I dont think the end links are the issue in this case. On mazdaspeed777's, he cant rotate the sway bar up and down without hitting the lateral links. Mine you can move it up and down without hitting anything.
strange...sorry guys..I have no answer. (peep)
I have been watching ask a ninja for almost 2 hours....thanks....im hooked!! http://www.youtube.com/watch?v=kzKcPiqmHN4&feature=related the ninja is totally right about Ohio... watery chilli and mediocre sports teams!!!
I have had the Progress 22mm rr sway with oem endlinks attached to tokico Illuminas for quite awhile. Have never broke an endlink or tab on strut nor is there any noise whatsoever. Mine is oriented above the lateral link bar. Close but not touchy.I mean the stocker never bent/broke and they have been through a lot but then again they also weren't attached to a 22 mm thick swaybar!
