Wagonbacker9
- 2004 'Hoe
I put a hitch on my car... the rear lip is now half removed for me.
to date: not a ******* thing.What do you pull on the hitch?
the theory was a 4 wheeler or wave runners... bike rack if necessary, or maybe a small cargo carrier. however in the nearly 2 years its been on there, I've yet to use the damn thing once.
Really the only reason its still there is because I don't want to try to remove it. Pretty good chance I'm going to have to cut through three 5/8" grade 8 bolts with a high speed cutoff wheel.
the back of the bolt is inside the frame channel... so its really not going to be that easy.
how else would you suggest doing it?(stoned)Why'd you do that? (lol2)
found out i need new cv joint, wheel bearing and hub to replace? any suggestions for where to shop?
ok so I finally got my LED white turn signal lights that switch over the amber, but I am wondering how to hook up my resisters so that they don't hyperflash... I remember seeing a diagram so that you just hook 1 up to the + and one -, but there are 3 wires coming out of the turn signal light.. so how am I suppose to hook them up?? any help would be awesome, thanks
Hook them up to the rear ones, only two wires. If you absolutely want to do it at the front:
Front LH is grey/black positive, black negative
Front RH in grey/white positive, black negative.
