quick question, I had bent the little spring inside the caliper holding the breaks in last year, I had a mechanic "fix" it, but it only worked for a week or so, it had dug into my rotor a good deal before he fixed it, but anyways last weekend I realized that the caliper was a reworked one and wasn't even really snug on the rotor like is should be, so I replaced the whole caliper on there with the stock one, and switched the break pads over like they were in the old one, I also used the springs(the things that hold the breakpads in) from the stock caliper so I know that is good, but I noticed that it still squeaked the other day when lightly breaking at very slow speeds, like when going to a stop sign around campus, I thought switching the calipers would fix that..
now my thought is that since the spring had originally put a nice little ring around the rotor, and it is just barely about level now so you can't really see it anymore(after a full year later, it was digging in there pretty good in a short time) that I would have had to have the rotor turned to keep it from squeaking maybe, but since it's drilled and slotted they didn't do that, or they just didn't do that anyways, but ya should I expect to have the squeak go away after it is flush again, and since nothing else is digging in, and since the break pads don't need to be replaced yet, and the others are fine I figure it's not because the break pads are warn out..
just curious if there are any simple explanations to this from anyone that has more experience with breaks and break pads ect...
