if he has the mp nick rebuild it MIGHT be possible.. otherwise, it's not helping him.
IF he is running that much boost he's definitely losing effeciency in the process. I once had my turbo running wide open because of a faulty boost controller, the highest it hit on me under WOT was about 15psi. 3rd gear burnouts uphill, lol.
dam... dont i gotta take my front dash out to replace that s***? dash = no fun......
No just remove the glove box and lossen the bottom and it will slideout... not that i have done that before. Never knew that it was this comon(eyeballs)
To bad we cant get the DDE angel eye kit anymore... They wont come off the size info either! I tried!
Wow, are you serious? Thats wack. I wanted them soooo badd!!! I still do :(
how are you going to wire them? same as they came on the p5 with a seperate hi and lo beam or dual beam for both?
i want to get them are run dual beam but it fails safety inspection here in pa
Wiring is a sinch, you won't fail any inspection if done correctly. You can't even tell mine aren't stock :cool:
yes, I'm dead serious. Remember I ordered a set and then for a refund with no explination. I then emailed them back seeing if they can give me the into on the ring size so I can just order them but never got a responce back.
I put that information you gave me for the headslights in a thread awhile back but I can't find them now!!
Edit:
FOUND THE INFO FOR P5 LIGHTS IN REG PRO!
http://www.mazdas247.com/forum/showthread.php?t=123741802
couldn't you just measure the size, and then go get some other brand like ddm tuning?http://www.ddmtuning.com/index.php?p=catalog&parent=84&pg=1
You can't measure them if you can't buy them, you can't buy them if they don't sell them, you can't ask if they don't answer.
