jonridinhi
- 2001 MP3/2010 MX5/1996 MILLINIA (donor)
I like dubs explanation better(dunno)
Well that was the plan but without taking a chance of tossing a bunch of money away guessing its not worth it beings they wont give you any info or even spond.
i can't imagine the circles being bigger/smaller than the 3's circles.. they're prolly pretty close.. just go and bake your headlight and take the plastic off nd measure. that way you dont need to spend money for no reason.
or you could just go to like.. oznium or something and get led strips.. and build some circles.
Its all find and dandy if I had the headlights which I dont as of yet.(silly)
i saw a how to somewhere on making your own angle eyes....not sure if it was here or on the ninjaforums
but basically they took a plastic clear rod and drilled holes in it every like 2 inches, heated it bent it and then put a single small bulb at one end so so it would light up and look like LED's where the holes where drilled
looked really good actually
Wiring is a sinch, you won't fail any inspection if done correctly. You can't even tell mine aren't stock![]()
No just remove the glove box and lossen the bottom and it will slideout... not that i have done that before. Never knew that it was this comon(eyeballs)
whew thats good to know....
boostdprotegelx and I changed the rear main seal on my MSP yesterday. It was the fourth time it has been replaced this year.
Seems to be holding up just fine, though. I've driven about 200 miles since the job and not a hint of a leak anywhere,thank God.
(thumb)
Damian to the rescue.... again!(bow)
