installed 626 mani. and pg sticker. I like these stickers much better than the outline ones he had.
the mani is great so far. I was running 10.5 with the supermap cause i cant log the AFR at the moment (thanks autometer). so i havent tuned it. but now im at about 11.3's woo hoo. lol
just need to fine tune some areas.
i hardly lost any throttle response or low end power, and got a really nice gain up top. Install went well, only had one snag and that was i had to adjust the throttle cable tension, but that took like 1 minute. i remember reading about he install back in the day, people make everything sound worse, you barely have to move vac lines, and u certainly dont have to take the stock mani apart to remove it...
Clean install (and clean part lol). Must be a new OEM; Looks much better than my junkyard one![]()
nice. cant wait to get 505's intake mani. Hopefully it works just as well.
are you running the dual setup? i assume you did not relocate your maf based on the pic in ur sig?
that is an old pic but no not yet, my turbohoses will finally ship tomorrow (I ordered awhile ago but when they sent the pipes to be ceramic coated it took the guy a long time to do them. they called and he said he forgot about them)) but would that cause me to still have the turkey by not having maf relocated?
So on a scale of 1-10 what would you rate this mod. 1 being not worth money and time and 10 being yeah, its worth the money. Also would you recommend this as a DIY or Pay. I normally dont do major engine work like this but it cant be that hard Right?
drove it today, dissapointed i still have the turkey with my forge bov. I called and they said i should have the green spring in the bov so i will try that. the guy kinda pissed me off though because he swore up and down the "flutter" or turkey as we call it is not compressor surge and is a standard byproduct of having a turbo. he also said a bypass valve and a blowoff valve were pretty much the same thing, i thought that a bpv recirculated the air and a bov discharged the excess air. other than stalling is there any other harm from running a bov only? i only ask because i am still waiting on my turbohoses harpipes and therefore cannot run a dual setup or do the maf relocate.
Terbow is quite right about the nipples being too small. Had Mazda put in a recirc valve with 1" or larger inlet and outlet, there would have been no turkey sound. Eventually when I get around to changing out my IC pipes I'll be putting a nipple in the cold pipe right behind the TB and attaching a recic valve to that. The recirc hose will then be routed to the intake pipe between the MAF and the turbo inlet. That's the proper way to do it if you want to recirc. Terbow is also right about the valve, BOV and BPV are the same thing, the difference is where the air from the valve outlet goes.theres a difference between turkey and flutter. the valve can flutter still cause of the spring, its just the way the air leaves the valve, thats y u adjust them. the turkey is the surge, its more of a loud wahhhhhhhhhhhh thing. for all intents and purposes the bov and bypass valve are the same. They are a valve that releases pressure from teh charge pipe when the car goes from boost to vac.
the forge valve isnt going to get rid of turkey, the problem is the nipples are too small (insert joke here). u need larger pathways for the air to get out. such as the reflex valve. i had 1" nipples (insert joke here), going to the 1" valve and i had no turkey. The stock sized valve is just too small to remove ALL noise.
if u dont have turkey then its ok, the flutter is fine, its never going to be perfect.
ok here is a stupid question so brace yourselves:
when running dual setup, i know where the bpv goes but i do not know how on the end of the bpv (opposite the hotpipe connection) to connect to the nipple on my sri, the sri manufacturer provided a pretty crappy u shaped pipe but it rattles and i dont want to use it so do i just run a vac hose from the end of the bpv to the nipple?
i dont understand.
but it goes from nipple on charge pipe to bpv inlet, then bpv outlet to the intake nipple (whatever it may look like).
then u run a vac hose to the vac nipple on the bpv.
right so from the bpv outlet you just run a silicone line to the intake nipple, that is what i thought i just was not sure
