Outlawstar98
- 2003 MazdaSpeed Protege / 2013 BRZ
Awd = better handling and cheaper insurance and can go off roading much easier lol
you would figure there would be a difference between Cleaning the tread which if you read threw the tread were cleaned after powder coating and the complete wrong size.. these were all wrong size i had to drill them threw and redo all of them.. no need for tape at this point in time.. as im not just "bolting on the intake" im doing other things as well.. with getting it Re coated since i burnt the first coating fixing the gaps and changing the throttle body..
the b.s. barb fitting that was supplied was used after giving it a few runs threw with the tap..result... you can see it.. once i drilled threw and actually removed material that's not paint i am removing... i verified with a 1/4 fitting i had laying around to the desired fitment that i wanted.. checked the 1/8th with end plugs since i wont be using any of them.. same thing had to drill out and re thread them..
Note: don't assume...
what i do when i time the car, is pull the cyl.1 spark plug and put 2 pretty long 3/8 extensions together into the cyl
then just turn the crank till it comes up, thats TDC, then just slip the belt on and put both cams pointing the line toward each other
obviously thats the quick way to do it, ive done the timing belt 3 times so far, worked perfect each time
