What have you done to your MS3 today?
No reserve on mine. 62 was the first year for the change. I have a gauge. The 64 was the last year for the "small window" body style. 65 had bigger passenger/quarter and windshield. What's really funny is that my 40hp beetle only bests the speed3 by about 2-3mpg highway. Highway = no faster than 65mph :)
are yellow fog lights legal? and do those melt to the fogs, I heard there was a problem with that on the standard 3
clos561 said:
how did u do it jsut take of and spray paint right?
They make a caliper kit. It's brushed on with a small paint brush. If you take your time and tape off what you do not want paint on, it can look professionally done. The kits are available @ Advance auto, Pepboys, and other automotive stores. You leave the calipers in place.
I painted mine similiarly, read a trick about using the old school little black foam brushes, they don't leave any brush marks and they didn't. I sprayed caliper paint directly on the brush and took my time painting the caliper on the car. easy, no mess ups and still looks great, no chips, i put on maybe four coats total. BTW I did this about two years ago and havent had to retouch it yet.
Mods
Did my first "under the hood" mod yesturday.
Installed a Mazdaspeed [AEM] CAI.
SWEET!
The little 2.0 actually feels like it has some grunt - sounds nice at speed too..
This is only the tip of the iceberg though...
Spring time will bring a 2" drop, cross-drilled rotors, a cat-back, a little computer tuning and ditching the pathetic 15" stock rims.
2007 is gonna be a good year!
Two things that I know of that will cause a problem w/these:
1. The independant fog mod and forgetting to turn them off when parked or stuck in traffic for extended periods of time. And,
2. Using overwattage bulbs.
And, I believe yellow fogs are legal in all 50 states, but wouldn't swear to it. I have yet to be questioned (stopped) about my blue ones here in Tejas and "they" seem to like to stop me for everything.
SwampAss said:
all fogs are yellow to my knowledge. Driving lights are white.
Yeah, but there is less and less distinction between the two nowadays. So does adding a yellow film on your driving lights turn them into fog lights? Hehe. The positioning is more what makes the difference now. As I'm sure you know, the closer the lamp is to the ground, the better, as the intent of the fog light is to light up the ground instead of the fog hovering right over it.
Eeeeeeee!! Thanks for playing, but you're both wrong.
The color of the beam has little/nothing to do with whether or not it's a fog light. The pattern, and to a much lesser extent the placement, is what determines it's nature/usage.
Accessory lights defined.
Fog/Cornering lights: Usually mounted low for best results w/a wide flat beam. Often yellow in color to help the driver see in foggy conditions, but when used as a cornering lamp, may be white in color and/or mounted up higher. Used only w/low beams.
e.g. I used a set of white fogs, mounted on top of the bumper, as cornering lights, and a set of yellow fogs underneath for poor conditions when I used to run street rally's w/my Volvo sedan.
Driving lights: Mounted @ the same level as the high beams whenever space allows and used in conjunction with them, they're nearly always white in color (some pro-racing series use yellow DL's to distiguish different classes running in the same race at the same time) and throw a long beam that is more focused (narrower) than std high beams, but more diverse than pencil/spot beams.
Combination beams: When mounting space is limited. W/dual lenses and sometimes dual bulbs these carry both a fog lens for a wide pattern and a driving lens for a more direct, focused pattern. Mounting should be between low and high as they are a compromise, and in my opinion should be avoided, especially if sharing a bulb for both functions.
Passing lights: I had a set on two different cars I owned and LOVED them, but they are hard to find in this country. These throw a narrower, longer beam than driving lights, but not as narrow as a pencil/spot beam. They always have a white lens and should be mounted and connected as driving lights would be (high beams only.) From my experience, they fill in that "hole" caused by std high beams that reflect light from the sides but seem to dissappear on blacktop. The effect of passing lights from the drivers seat is one of a completely lighted oval pattern. As I'd said, I loved mine a lot.
Pencil/spot beam: Always white and mounted wherever additional light is needed, but usually high, as near the high beams as possible. These throw a very long, narrow (focused) pattern and should only be used w/high beam headlights.
Also, remember that any light will make the most of it's available output if mounted in a round (parabolic) reflector/round lens, and in this case bigger is better. That's one reason I am not a fan of the new Mazda fogs.
I hope this helps define accessory lights.
ZZZZzzzzzzzzzz. Huh?!? You said something? just messing with you. Do I pass the test if I now say the little lights mounted low on my car throwing the photons low and wide are fogs?
I think the round ones look better, too, in addition to their design superiority.
What I did to my 3? Two days ago, in an effort to get all the way over to the curbside of a parking space (to try to avoid the inevitable door ding), I scraped the right front wheel.(pissed) The worst part is, the spot I was shying away from was empty. I'll try to fix it up this weekend, when I give 'er a good washy-waxy.
You might, Rabbit. You might.
BKK Jack said:
What I did to my 3? Two days ago, in an effort to get all the way over to the curbside of a parking space (to try to avoid the inevitable door ding), I scraped the right front wheel. (pissed) The worst part is, the spot I was shying away from was empty. I'll try to fix it up this weekend, when I give 'er a good washy-waxy.
OUCH!! You're first boo-boo. And before any of us saw any REAL PICS of her too.
If it makes you feel any better, and it won't, I'm sure we've all been there at one time or another. Alloy wheels are like that.
I scrapped one of mine on a high curb and a badly designed tight right turn in a parking garage last year. A file and utility knife (sacrificial blade) took care of most of it. I notice it, but I don't think others usually do.
Thanks for the tip. I'm going to get some wet/dry sandpaper, and hopefully some clear-coat. Do "they" sell brush-on clear-coat for wheels, like the touch-up paint?
You can get clear coat in a spray can
