What have you done to your MS3 today?
I've sold mine as well, in favor of a Lexus GX470. Growing family and the opportunity for offroading/overland camping drive me to an SUV for daily driving. I still have my RX8 for the summer though!
Changed the oil. I let it go a bit too long. Last change was 5/7/16 (9 kilomiles ago) (whistle).
Engine failed in spectacular fashion in early January. Not in boost, not under load, just cruising along, started misfiring (MIL flashing) and BOOM at 197,702 miles.
So, picked up an 08 CX7 (99K) that had the engine disassembled after a timing chain failure with the cylinder head gone through at a machine shop and an intact bottom-end for $1,000. Just got it for the engine, but it is in such good condition that I decided to keep it and get it going. Grabbed another CX7 engine with a blown head gasket for $150, had to remove it myself and am starting the process of rebuilding this one. Also picked up a CX5 as a daily. Fun times.
Hello, long time no post. Still got the car with 64,7xx miles on it. I had low boost issues due to burnt down pipe so bought new one and wrap the inter cooler pipes with heat wrap because of tight fit pipes rub against each other. I gain 36.02hp & and 21.86lbft by installing a CorkSport Turbo and the 3.5 bar map sensor that came with it. So now car is making 346.02hp and 376.46lbft at 21psi on the dynapack with 91 pump gas. OEM turbo was tuned at 19psi. Done other work here and there but so far car is doing fine.
Pair of Continental DWS/06s to replace two that were too worn to repair. I'm done with Discount Tires. They denied the mileage warranty claiming the tires had not been rotated enough. That explains why I had to do the last two rotations. They were stalling to get out of the warranty.
Installed a used engine, new clutch, new braided clutch line, new starter and a bunch of other items. Need rear sway bar brackets because I keep bending the cheap ones.
Wednesday night I hit a desktop-size chunk of concrete in the road. Both right-side tires and wheels are toast. Fortunately, nothing else is hurt. I bet the right front wheel is aimed a bit out now. Tires and wheels coming Thursday or sooner.
Added this to the stable last week:
Magnaflow mufflers and 4" tips today, tint tomorrow.
Got my passenger side headlight restored over the weekend.
Gonna fire this thread back up again. Pic of my 2012. Detailed it inside and out. Night shot. Not too many clean Speed3's remaining, I'm tempted to take mine back to stock sometimes.
I cleaned my car thoroughly and made her shine like new before winter comes. Also just threw the winters on. Going to get some tint all around and did an oil change as well as put some sea foam in the gas tank.
I am getting my parts together to do a front shock replacement on my 2008 MS3. My right front Koni yellow is leaking. While there, I am vacillating between replacing the lower front control arms or not. I have the Delphi aftermarket ones in hand, but later realized that there is only a single Delphi fitment (per side) for the regular 3 and for the MS3. The Mazda parts fiche has different part numbers for the regular 3 and the MS3. I have a separate thread on the forum asking about the difference between MS3 factory lower control arm and aftermarket units.
I looked at the head on the kitchen table and block, on a stand next to it, and reflect on the fact that I started this build, in a way, 15 years ago, before I got that dog, before many things.
