Chris_Top_Her
Contributor
- San Antonio, Texas
- '15 CX-5 Miata AWD
Considering fabbing a single exit exhaust.. since our oem dual is style/sound supression only.
What plug is that and what is the weeping oil you are referring to?Threw a cel on the motorway, pulled over and pulled the code. Look at my oil control valve and the ground wire came apart. Hey at least this one isn't "weeping" oil. Should be a simple splice operation once I get the old wire out (gonna fix both). In the mean time just will want to stay out of higher cam profile (below 4k rpm) to avoid low oil pressure
Damn....I knew it would be cheaper for the CX-5 (more popular car). Rockauto sells the exact same thing...for more money.
Rockauto: JPOWER STOP JBR1745XPR Extreme Performance Drilled and Slotted= $63 per 1 front rotor.
How else are they supposed to pay for all of their ads?
Well didn't do anything to my CX-5 but it did do something to me (entirely my fault though).
For the first time in my life, I somehow managed to slam my middle finger in the door. Had to unlock it with fob and open the door to get out. Stitched up fingers are "fun". No broken bones or fractures or anything so guess it could be worse.
OUCH! Just glad you were able to reach the fob with the other hand! Cut bad?
Installed Evo One remote start. Does the horn have to be so loud![]()
Thats a lot of work especially your job included flywheel rotation. I did the starter job a while ago on my 1998 Honda CR-V by cleaning up all the carbon and metal debris inside and lubricating all moving parts. Most people would just get a rebuild starter and replace it.Starter was clinging badly when starting for the first time of the day since the weather went down to the 50s/60s. I removed it, disassembled cleaned it, put it back on and it was worse. Tom it off and rotated the flex plate (flywheel) a little reinstalled it and it was good. Gonna start it in a little bit hopefully the fix persisted. Edit so far so good!
Ouch! Hope you have been recovering well!Skin was split apart and was kind of a long cut. Just needed it stitched back together, but was otherwise fine.
That*s a lot of work especially your job included flywheel rotation. I did the starter job a while ago on my 1998 Honda CR-V by cleaning up all the carbon and metal debris inside and lubricating all moving parts. Most people would just get a rebuild starter and replace it.
Stitches are out, thanks!
Just had my Blizzak WS90 tires in 225/65 17" put on today. We are in for snow through Wednesday and I have to go up to the mountains on Wednesday.
