Water damaging front door speaker
So, with the nice weather I decided to investigate why the right front speaker sounded muted, turns out, when it rains water comes in through the window sweep edges. with enough water it starts literally raining inside the door and it gets on nearly everything. I have found a part on mazda-parts.com B25D-58-821A that I think is it but not 100% sure yet.
You can check the part number in the parts catalog.
looks like the parts online (across many sites I found) have the part number slightly different but it looks like the same part. the barely visible car pic there seems to have them highlighted. as a bonus I found the PN for the front lower grille mesh I am missing.
You know that you clicked on the 4-door.
The 5-door P5 may have a different shape or size ??
5040A and 5040B
I think that I remember that the two front doors are identical between the Protege sedan and the Protege5, it's the rear doors that are different.??
So you might be OK.
But you did say that your right-hand speaker was going out, and you posted a link of the lefthand side...
