accuser said:get some awr motor mount (both front and rear) that will definately help you out with the torque steer and the wheel hop...
i dont have wheel hop, i have a front mount
boost is fun... enjoy the kit... don't get too boost happy... (and please dont put one of those "boost inside" stickers on your car... too many ricers out their already)
give me some credit this is my second kit
car looks good... keep up the good work... who installed your kit? did you install it yourself?
myself
-pedro
10psi? With no timing control? Better get a motor on order...accuser said:matt... i'm glad you enjoy the kit... i've got a custom kit with some mam parts... and i love them... the disco potato is definately the way to go... my gt28r spools at like 2200 - 2500. the mam downpipe is awesome... i always say... simplicity at it's best... the downpipe is simple... and rocks... you hear EVERYTHING... from valves... to waste gate... to turbo spool up...
i'm running 10 lbs (so my gauge says... i still have to verify what spring is in this wastegate... they told me it was a 6.5) the car freakin rips... i got a begi and a volatage clamp...
the ecu isn't pulling fuel because you are at WOT when pushing boost... get into boost without WOT and you will see that the ecu will pull fuel (open loop vs closed loop)
-pedro
Link to pics of your setup?Matthew said:sleeper. i know its nothing compared to 15psi but it feels so great to be boostin again.
Yeah, that rear mount is tough. Hopefully if my rear mount proves to last you can run one of those someday.Matthew said:i had the rear mount got rid of it.
lol..im so used to posting so soon after people most times other people dont get posts in before me (see sig for some more pics but not quite the latest, as well as mods)Kooldino said:Learn how to use quotes, n00b. <3
i gave up trying to get that b**** in. everything i do with my car is by myself. all my friends would say "yea ill help with the turbo etc" and instead i normally end up with the car on a lift, me sitting on the lift with my left leg under the car holding up the downpipe and exhaust while i bolt it to the mani/turbo.Kooldino said:Yeah, that rear mount is tough. Hopefully if my rear mount proves to last you can run one of those someday.
I'm talking about this: you replied in HIS quote block...Matthew said:lol..im so used to posting so soon after people most times other people dont get posts in before me (see sig for some more pics but not quite the latest, as well as mods)
Needs moar friend.Matthew said:i gave up trying to get that b**** in. everything i do with my car is by myself. all my friends would say "yea ill help with the turbo etc" and instead i normally end up with the car on a lift, me sitting on the lift with my left leg under the car holding up the downpipe and exhaust while i bolt it to the mani/turbo.
