wagner fmic install help intake question
use the hose that went onto the factory intake pipe, sorry for the blurry pic. took with my cell phone but hope it helps. (heres more) mazdaspeedchick heres the bolt that holds the pipes together from Wagner that you were looking for.
Damn i am missing the threaded fitting and a way to connect the MAF to the intake pipe. guess i won't be driving my car for awhile:(
I am missing the silicone coupling between the MAF and the intake tube. hard to get a pic of that. can you show me where you relocated your coolant overflow?
sorry my ******* digital camera is acting up I'll take some for you tomorrow when the light is out. not a bushing the rubber boot that holds them together with some band clamps Andrew should have given you the better band clamps sorry I forget what there called.
Ya I got mine in Dec or Feb, Andrew custom built mine cause I wanted a bigger core and he add that bolt to hold the pipes together I'm sure if you go up there he'll weld one up for you, looks good though keep up the good work on your speed!!
