Ughhh.... Help!!!!!!!!!!!!!!!
That light comes on when ur pressure is low low low, so you should check it out and make sure u have enough oil in ur motor
ok i got my oil pressure guage hooked up
the pics r when the car was warm and it was at idle
it was about 30 degrees outside too
Seems normal, how about when you drive? It should be pretty responsive under gas to your rpms, doesn't really go higher than 60psi when the car is fully warmed up.
The oil pressure sensor might just be bad, causing the light to flicker
o forgot to mention bout the light, i had a knN filter on their, changed that out too and no more flickering light!!
EDIT: when u say pretty responsive, would u say kinda like a boost guage?
FmL!!!!!!!!!!!!!!!!!!!!!
I THINK MY s*** JUS SPUN ANOTHER F*CKIN BEARING!
I HAVE THE WORST LUCK EVER!!!
SO NOW IM IN THE MARKET FOR A NEW ENGINE AGAIN :( I JUS WANT TO GET MY s*** RUNNIN RIGHT AND BE RELIABLE!!! ILL BE OFF TO COLLEGE THIS YEAR AND CANT AFFORD TO KEEP IT UP, SO I MIGHT JUS SELL THE TURBO KIT ALSO
ALL IN ALL, ANY ONE SELLIN AN ENGINE FOR CHEAP!?!?! HELP A MAZDA LOVER OUT
I would say it is probably due to how hard you drive that thing...although it is turboed, it is not a red light racer...
i wasnt even drivin it that hard!!! ive been actually takin it easy tryin to get more miles outa my tank, while occasionaly punchin it
like i said lets see if u cant just replace the bearings before jumping into replacing the motor again. may save u some money
not to mention if the block is damaged to? idk i got it towed to TDC today, the guys over there r goin to check it out for me for free, i think... ill let yall know what they say.
o btw, dyno night is rescheduled for march 20 and its gunna be $20 for 3 pulls!!!!!!!!!!!
