the microtech doesnt have closed loop fuel control so i cant use this solution.Sleepy said:I don't have any idle problems nowMy idle control was messed up before the cams went in, but with some more fiddling around, it's working again and so is the closed loop. I put a relay in the O2S input and activate it with the auxilliary output to open the O2S circuit and make the PCM go open loop wherever I want it to so I can tune the AFR without worrying about fighting with PCM's closed loop. I need to have the TAS open a bit(1% TPS instead of 2.8% with full overlap), with AAS all the way out to idle well at about 750rpm.
I need to get an input on my accessories to trigger idle up...i'll get onto that one day when i'm not feeling so lazy
you considering pushing back for full overlap now you've got it working?
Oh twiggy cams were instrumental in assisting my car pull down a new PB, 15.206@89.82mph
