sounds like mineTopher said:car pulls HARD over 4K...i'm catless with a side exit exhaust, sounds v8-ish...pretty bad ass. i like them. wish i had some for my msp.
Sleepy said:it's working again and so is the closed loop. I put a relay in the O2S input and activate it with the auxilliary output to open the O2S circuit and make the PCM go open loop wherever I want it to so I can tune the AFR without worrying about fighting with PCM's closed loop. I need to have the TAS open a bit(1% TPS instead of 2.8% with full overlap), with AAS all the way out to idle well at about 750rpm.
Pretty sure sleepy runs a piggy back unitCrazee D said:Do you think this is possible for Piggyback users? or standalone only?
LordWorm said:Pretty sure sleepy runs a piggy back unit![]()
get readyshabaka said:it's true, they do
wow my set is actually done
hopefully i can post my results/question here soon (eekdance)
bump the idle up a shadeSleepy said:Overlap now halfway between NA and FI. Goes fine and just sounds a little grumpy at idle sometimes. The PCM's closed loop is pretty loose, allowing the mixture to get a bit lean as it cycles from about 14.1 to 15.3. I tuned it real accurate and steady when it was permanent open loop (14.6-14.8 while cruising). These cams don't like lean mixtures.
The big overlap probably contributed to the demise of my #1 and #2 engine mounts. I've filled them with epoxy putty while waiting for AWRs.
Any answers for my threadlock question?
yes, yes it isCrazee D said:Dema mentioned exh lift is quite substantial.
i checked my lash, was within acceptable limits.Crazee D said:So back on topic...anyone have install advice? Did anyone check lash or did u just drop em in?
working on it now - i have a few leads, i might be able to reduce the "range" that the microtech controls the idle under, so it doesn't try and spit the idle up to max insanity levels when it feels a stall, and doesn't fart arse around when it really needs to....AusOrion said:I hope that Lordworm can find a workable solution for the idle under Microtech in the near future cause I want to keep the rythmic "drum beat" that I have now.
