I emailed Knight Turbos about their turbo/sc kits for the 2.0 mazda fs engines..................................................this is what they said "Sure,
2.0 FS MAZDA 4-CYL SUPERCHARGER AND TURBO KIT INFO:
The stock 4-cyl 2 0 engines produce between 127 and 135 flywheel hp (98-105 wheel hp). The hp will jump to 200-225 flywheel hp (165-185 wheel hp) @ 5-7 psi with either kit. I always recommend upgraded pistons and rods in the future, and can supply them as well as a stroker kit. This will allow for a lot more boost and power. Each psi of boost will add 10-15 hp, depending on how well the engine is built.
A bone stock FS 4-cyl 5-speed car will run 16.8 to 17.1 in the 1/4. With the turbo or SC kit, slicks, and a good clutch these cars run 14.6 to 14.8 at 92 to 95 mph.
The turbo kit ($3795) include a huge hybrid T3T04 turbo, front turbo header, huge front mount intercooler, mandrel-bent intercooler pipes, hoses and clamps, downpipe, FMU fuel management system, inline booster fuel pump, and braided steel turbo oil supply lines.
Included accessories are:
boost, air-fuel gauges
high flow air filter
high flow exhaust--3" mandrel bent pipe set.
silicone hoses & clamps
aluminum intercooler pipes--$200 upgrade--(available with kit only)
60-1 full race turbo upgrade--$300
The SC kits are $3795, and feature a sheet metal custom blower manifold, pulleys, Eaton 62 CID SC unit, aluminum T-body plenum, By-Pass , and larger throttle body. as well as all the accessories listed above."
Thomas (Geoff) Knight
THOMAS KNIGHT TURBOS
Phone: 786-243-2000
Toll Free: 866-361-6502
22050 SW 155 Ave.
Phone: 786-243-2000
22050 SW 155 Ave.
