Turbo Rebuild
PROZERO-3
03 Protege es
Does anyone know of any company that makes a rebuild kit for our turbo all i seem to be finding are for the regular t25 but will the gaskets fit right up and be able to work ok. my turbo seems to be having a little bit of shaft play or is the anyway to correct the problem thanks
Modern Performance Inc. does rebuilds on our turbos...
his SN is MPNick but isnt active on here anymore because people caused too much BS... you can try to search the forums for his contact info...
Try sending him a PM, he answered mine a few weeks ago. The upgrade costs about $700, which includes work on the manifold and dp, as well as upgrading the turbo.
I was told by a turbo rebuilding company that the ball bearing center sections are not rebuildable. Therefore, if you have shaft play you will need to get a new center section. I think what nick does is just replace the compressor housing and the turbine wheel.
Mine had shaft play before it went in, and had none when it came back
Well I'm a HMT member and I recomend Blaast Performance they do top notch work and have great prices, if you e-mail them they will get back to you asap and they have great customer feedback
http://www.blaastperformance.com/
Preventive rebuild - Garrett T25, T28 turbochargers $149
