Possible to get a CX-5 OEM Transaxle rebuild kit?
Is it possible to get an oem transaxle rebuild kit for a CX-5?
I'm wanting to rebuild my old slipping transaxle after changing it out with the remanufactured one.
Have yet to find a rebuild kit..
You can buy a seal kit from Mazda but not an overhaul kit. You'll need to buy steels, clutches, any hard parts like the one-way clutch, etc separate. To correctly overhaul the unit you need a special socket(or make one) to remove the large center nut in the case or you'll be unable to completely disassemble the units. You'll also need to buy a new input drum if you have any issues with the Low Clutch apply piston because of how the drum is laser welded together it is not replaceable. Any valve body repairs will require oversized valves and those are not readily available, I have special oversized valves that we use so we do not have to buy a new valve body from Mazda during overhaul.
Upvote 0
Acknowledged! (Thank you for the insight sinistriel!)
Appreciate the detailed answer!
Upvote 0
New Threads
