Thought i would chime in but just to add to the k-sport=junk part of this thread....third shock in less than 20k miles is officially toast
wow; leaking? what year did you buy these, out of curiosity?
boing boing boing boing! As if your car didn't bounce bad enough with the rears blown
Doesn't BC make K-sport? lol
second, apparently KSport changed ownership about two years ago. KSport has admitted that the quality of their early products was not so good. they have since obtained a TuV approval and ISO 9001 cert; this means their manufacturing methods are sound and their quality control program is sound.
it has been admittedly difficult to separate the cases into old product versus new, improper installation vs. correct installation. in shadow's case above, his dampers are more than two years old AND he purchased them used. there's no telling how they were installed / used / abused on the previous vehicle. it would be imprudent to simply blame the manufacturer without making room for the possibility that the previous owner could shoulder some responsibility.
The ride was too bouncy for me, so I sold them. I put my TEINs back on, but have since installed BC Coilovers (see sig).
As far as the graph, i think he's trying to show how different the dampers are from one strut to the other. How can you expect a smooth, consistent ride when the dampers are so different (both set to full soft, then to full stiff)?
My issue is the fact that i know they went through this big change and yet they have no contingency to help the owners of their older product. Why should i pay $400 to replace all my shocks if they KNOW their is a problem with them.
10"/second is the peak velocity, so the ramp up to get up there is how it calculates the other displacments as the crank shaft on the dyno moves 180 degrees at a time for the full 360 revolution. If we were to run it at 10"/second then yes, it would be constant on rebound/compression.jeff -
why does force vary with displacement at a continuous velocity? shouldn't it be more or less one constant for compression and another for rebound? i can see how a cv plot could be useful to verify performance through the entire motion range. why is 10" per second the standard rate?
thanks for posting the velocity graphs. i do have a question, though. on your velocity plots, how come your graphs show a force at zero velocity? shouldn't the graphs start at zero force / zero velocity? i think the plots i've seen start at zero force or very close to it.
what does the industry consider to be a 'good' match between dampers? 5% difference?
thanks for your input.
one more question on the 10" / sec continuous rate: is this considered a 'high speed' (i.e. hitting bumps) or 'low speed' (i.e. cornering) metric?
on the first chart, what caused the break circled in red here?
10" per second is the standard rate for us because we feel that is about as much as a car would see on the street/track. I know Koni NA tests 10"+/second.
It's from the gas pressures from what I've heard. I'm not 100% sure myself.
I believe our standard is the same as Koni NA which is 10%.
10"/sec is considered high speed bumps. The low speed control is typically between 3 - 4"/sec.
