So I've been researching a bit about a certain noise coming from my transmission and it seems to be my throwout bearing is failing.
my symptoms are squealing/shrieking in reverse grinding sound in neutral and once the clutch is pressed in it'll stop grinding. My father in law will help me with the repair but I need to know the exact parts that are recommended to replace as well with the bearing, that way I don't have to drop the tranny more than once. I plan on getting the stage 2 clutch and an aluminum flywheel. Other than that I would like to know the tools required and other commonly failed parts in the transmission. What brands do you recommend on the clutch and flywheel? Also I will be purchasing the bearing from racing beat anything with a Mazda 2.0 manual trans will be the correct bearing right?
Thanks for your time.
