mazdaspeedson
- 2003 mazdaspeed protege
my car seemed to have clutch issues it wouldnt move as if the clutch was slipping replaced the clutch not the issue the car will not move when it happened i was pulling out of the parking lot i heard very faintly a clunking almost like a axle 10 feet later the car wont move. if you jack the car off the ground it rolls and makes horrible noise also you can put the car into gear while it is running all gears i have thought it was the differential before i put the clutch in any help would be great
