Touchscreen option not shown on Mazda CX-5 2025 Saudi Arabia
I bought a Mazda CX-5 2025 in Saudi Arabia. I tried to find the touchscreen option while using CarPlay but it does not appear.
Is there a way to update the framework? Or how to add this option?
Version Information
System Software: 11004
Gracenote Database 1.1.1.02325
I have the exact same situation (KSA too, even when the car is not in driving mode), tried everything but the option is not there...
Finally, I contacted the dealer and he said that the option is disabled in my firmware version by Mazda itself!
Hopefully they will re-enable it again in future updates...
Upvote 0
In the US the screen isn't touch unless you are stopped or using CarPlay or AA. I personally don't use the touchscreen in my CX50 Hybrid or my 19 CX5. In fact the 19 CX5 came down with a bad case of the ghost touch so I just pulled the unit and disconnected the ribbon cable that supports the touch screen. I always just use the jog wheel.
Upvote 0
Version Information
A software update will not fix this. Your current firmware version (11004) already fully supports touchscreen functionality. The issue is your physical hardware.
The Details:
  • Missing Hardware: In the Middle East market, Mazda installs a 10.25-inch display in CX-5 2025 that physically lacks the touch digitizer layer on many trims (likely part number KGC2-61-1J0).
  • Hidden Menu: Because your car's main computer (CMU) detects that the monitor has no touch capabilities, it completely hides the "Touchscreen" settings from your connectivity menus.
  • The Only Solution (not confirmed): The only way to add this option is to physically buy and replace the display monitor from a top-trim/North American model (part KDPW-61-1J0 or K19G-61-1J0) and swap it into your dashboard, then somehow to enable it with FORScan, because even with a hardware support that has to be enabled in CMU.
Upvote 0
