JCell said:quick question about soldering..
when i solder wires, i just twist the wires together and then cover them with melted solder.....i usually get a big solder ball by doing this
is this bad?
Like Ryan said, if you heat up the wire enough, the solder will suck into it. A ball of solder does nothing, you need the solder to get sucked in. You should see the outlines of some of the strands, that way you know it was sucked it. When I solder, once it's sucked in, I add a bit more solder then flick the wire a little to get rid of the excess solder. Sometimes it will hit you, but you know you don't have too much on.
Solder shoud bond the wires together from the inside out, not hold them together from the outside only.
