I just replaced my valve cover gasket and I'm worried about oil leaking past through where the cams are. There is an oily mess everywhere from the leaky gasket before, but the timing belt looked good and didn't have any oil on it. I just want to be able to look in there and make sure the problem is fixed.
Is it possible to remove the upper timing cover without first taking off the valve cover?
Looks like it will come off by removing the four bolts and moving it sideways. But no one ever mentions doing this and I'm wondering if there's something that prevents you.
Edit: It's an '02, sorry.
