Shawn89255
- 2003.5 MSP-CAI,Unichip@12-15psi,AFC,Reflash,Colder Plugs,626Mani
Harbor Freight is the *hit
I always knew the ticking was normal, but the OPs issue definitely isnt the normal ticking lol
subbing to listen to sound, my motor is loud ticking too all the the time, it wont go away and now i have a vibrating noise coming from the bay (bad motormount?)
most likely valve tick. Mine does that too when the oil is still cold but then goes away
I wouldn't even run it long. Do you have a friend thats a technician? Hopefully you do, but if not. I would recommend just taking it to a mechanic to atleast just diagnose it. Usually a dealership will charge somewhere from $85-$185 to diagnose it, but atleast you will know what the problem is. If you do you end up blowing up the motor, I found a motor for about $1000. Keep us updated.
