incorrect information. First and foremost, you want methanol for the OCTANE insurance, not because your injectors are maxed out. If your injectors are maxxed out, you best be fixing that problem before adding meth injection.
Yes, the water aids in cooling the intake charge. It also helps atomize the methanol. Youre roughly at 103 octane while injecting a 50/50 mix. However, 130 octane is reached running 100% methanol.. i do this at the track for obvious reasons. Running straight water does nothing but cool the intake charge, without increasing octane.
I said nothing different... your points about octane might be valid (I doubt the 103 octane calculation however) but not my argument. Also you are not just cooling the intake charge when you inject past intercooler but as well the actual combustion. This in fact has a higher effect on knock protection then the a slight increase of octane number, which can not be 103 as you stated before with liquid methanol having a R+M/2 rating of just 99.
