The Ohio Random Thread... aka We Should Probably Be Working
did that on my protege except made them completely seperate, so i could have them with high beams too. i might do it. but i have 2 5 inch round fogs im gonna hide behind my grille on this car.
the parking lights stay on when the high beams are on in my car. I don't want the fogs on when the key is on acc. That would be obnoxious and annoying when I'm using the car radio when working on my car.
I was just thinking the extreme temps back and forth would crack the rotors and the ducts get jammed up with snow, slush and junk. But it might be just fine. What do I know!? haha
Regarding the extreme temps... it's already going to do that in the winter, regardless of ducting. Plugging with snowy crap... yeah, that makes a ton of sense there! For some reason, I didn't think of that... even tho I was always covering the fogs on my P5 with snow/slush
i meant the fogs with my high beams. they were completely seperately switched.
Ah yes. Technically (i guess legally), you cant have more than 4 "headlights" running at the same time. Thats why the fogs shut off when you flick your highbeams on.
Anyone have an extra set of gen1 foglight housings? Ive had these first gen 350z projectors laying around for years and theyd be perfect for a foglight retrofit.
yeah But if you wire the fogs to come on with the parking lights wouldn't they stay on when you turn the high beams on being that the orange parking lights stay on when the high beams are on
Do you guys have any kind of aero data for your cars? I can't remember if it was the Neons or not that had a low pressure zone where the foglights were located. If that was the case for your cars, I'd lean more towards putting ducts in the rad opening. Also, Miatas have bolt on ducting available through the aftermarket, but it's only the sheet metal that surrounds the rotor and attaches to the hub. I believe track speed engineering offers them, if anyone wants an example. It forces the air from your ducting hose onto the rotor by shrouding around it.
Edit: also if you notice where 949racing places their ducting, it's closer to the middle of the car. Also note the tiny radiator opening. I guess this is the best compromise for aero while still allowing as much cooling as possible. I haven't had a chance to read up on it much but I'd imagine the concept is similar to having a "too big" exhaust on a stock car, as far as usable air coming in that opening vs surface area(not even sure if that's the right term).
There's a lot of aero data floating around on the RX7. I recall seeing a 2D pressure map on a profile of a car so it shows the pressure distribution along the length of the car, but not its width. The ducts you're describing for the Miata sound an awful lot like the ones I posted for the RX7 a page back.
For radiator ducting the rule-of-thumb I always heard was you wanted the inlet to be 25-30% of the radiator area and then smoothly transition to the full size of the radiator. I figure the reason is two-fold:
1) Reduces the aerodynamic impact of having a large duct (huge drag)
2) Convective heat transfer for laminar flow is greater at lower velocities for air (to a certain point). That is you want the air traveling slow enough to pick up as much heat from the radiator as possible but not so slow that it "heat soaks" before it passes through the radiator. With the smaller inlet you're expanding the air as it enters the car, which reduces ites velocity (unless you're traveling at supersonic speeds) and therefore improving heat transfer.
I'm sure there's a lot more it than that but this is how I've rationalized it.
That's explained a lot better than I did haha. And my service is horrible here at work I don't think your pic on the previous even loaded for me!
That sounds correct, unless of course you flip the switch to off for the fogs
Nope. I've done the same thing to my P5 and the fogs turn off when I turn the hi-beams on, so you are good to go.
oh I want to see if I can light up the sides of the road with the fogs with the brights on. There are a lot of deer around where I live and its hard to keep an eye as it is
I don't think I've ever been in a car with fog lights on and say "Wow! Those really help!". Fog lights are useless...
Well since my low beams blow mine actually help. They hit that crucial ditch/tree area on the side of the road. I have 55 watt 6000k HID fogs. Yes stock they are stupid useless
