Holy shitballs! It's freaking POURING out tonight!
Almost had another bad water incident tonight, like the time Evan and I were stranded on the side of the highway because my car sucked up some water/moisture. There was a LOT of standing water on the way back from the grocery store, and the car started acting like it did before when this happened. Luckily, it must not've sucked up enough to kill the car completely. That, or the bypass valve I installed after the first incident worked! The car was running like dog s***, and the CEL came on, but it stayed running enough to limp home, about a mile and a half.
Letting it dry out in the garage overnight, hopefully all will be well tomorrow. Finally get to use the scanner I bought after the last incident too! Haven't needed it...lol
What are bath salts?...Trent -- reportedly high on bath salts -- ...
I'm always afraid of this happening with my CAI. Luckily I haven't had any problems yet.
I don't recommend it.
pre-filters or driving through deep water?
Get a K&N pre-filter, fo sho. I had a lot of problems with my filter and MAF getting wet and my car would run like poo after the swap. Since I got the pre-filter I haven't had a problem since.
And did you ever get the lower splash shield installed?
Kevin, you need those for the winter too, buddy. Or at least get rid of that CAI set-up for the winter. We are not going to do another swap for a couple months...![]()
