I would if I could.... Won't be back in stock till early next year. Well until the release date is pushed again
Aaah, should have known. They never have s*** in stock.
See, this is why I don't do autocross lol. I just don't get why you would limit yourself to a certain standard. I would rather do whatever I want since it's my car lol. Put a little wider wheel and tire and it fits exactly what I want: looks better and handles better. To each his own, I guess.
I knew I never wanted to compete so I built it for me! And yep those are the only ones that applied lol.Or actual wheel to wheel racing. They all have a rule set to follow. Some people's goals are different than others. Me? My goal is to compete.
Step 1: Find what class fits your goal and budget best
Step 2: Question your sanity a few times as you drain your savings account
Step 3: Get stuck on something and then proceed to wonder why you drained your savings
Step 4: Re-read the rule book 50 times to try to figure out what else you need to buy
Step 5: Keep telling yourself it will be ready one of these days.
I think step 2, 3, and 5 applied to the LS car, right?
You should try and get the Mazdaspeed Motorsports discount for the Miata. You should send them your SCCA Reg, and pictures of the car, with the class your running etc., they may have the wheels in stock.
sad that I didn't make it to Menchies. I was helping Baby Marc replace his rear struts and then I was getting the new motor for the miata to my house.
Morning all. How was everyone's weekend? Spent 3.5 hours cleaning the Bavaria for the BMW CCA cars and coffee event. Had the oldest one there until BJ showed up with his '72 2002. If it wasn't for the rain, I'm sure there would have been more people there. Made a few contacts to both sell and buy parts while there. With any luck, I'll be able to find some of the hard to find bits for the Bavaria.
Should be this week. I am waiting on parts from Mazda that will be here Thursday. I am stuck on one last bolt on the transmission before the motor can come out. Maybe someone here can help. The bolt I am having an issue with is on the driver's side of the transmission into the block and there is a bracket that has two bolts holding it onto the tranny. I got the lower one but the upper one I cannot get anything to seat on properly as there is a rusted bolt in the way pushing the socket up. If I can't think of anything today then I am going to use my sedaline torch and cut the chunk of the bracket off that is keeping me from getting the last bolt.So when does the motor go in?
Also this engine bay is NASTY! I think he either drove on a beach or took it through a beach at Mid Ohio. Everything is covered in this sand/oil/grime coating and its gross. When the motor finally comes out everything is getting a good scrub down to get this engine bay cleaned up.
Try a super long extension with swivel at the end. You can also try a set of bolt/nut removers http://www.sears.com/craftsman-10-p...p-00952165000P?prdNo=3&blockNo=3&blockType=G3
I have a set you can borrow if you need them. I call them my backup plan.
I think we used a lot of extensions on Will's car and got it from the bottom. Take a pic if you can to confirm.
yes I have a set of those. I just didn't want to use them on a bolt I am planning on putting back in haha
