I did this like a week ago. Amazing.I got annoyed of the suspension and I turned it all the way soft. I thought I'd share that with you, lol.
Dude... your car just keeps getting sicker bro. Keep it up man!
Sick!! Tranny holding 800whp in question would be?? I may see a major swap going on with the red wagon![]()
I have a PAR 1-4 straightcut gear setup since going through several 3rd gears. Still need a par output shaft, crownwheel bearing reinforcement cups and an mfactory diff. PAR gears are heat-treated shotpeened and cryotreated and are still only rated for 500hp with the bearing cups to help reduce caseflex which is the main issue causing oem helical cut gear destruction. Straightcut gears help to eliminate alot of this issue.
Thanks man 400ish was my goal and I'm fairly close...before I read your update!![]()
