TEIN coilover on P5
MIT
2003 P5
1. Does anyone using TEIN SS coilover or TEIN basic coilover on P5?
2. Is it good in handling? I am thinking to get the basic one because of $$$.
3. Will it fit properly on P5 without any modification? Simple swap?
4. Does it work with the stock sway bars? No $$$ to change it at once.
the SS will gie you 16 way adj. where as the basic is only height adj.. it will bolt right in and works with the sway bars the SS will run you about $1200
ull get a stiffer ride i assume and better handling :) u can pm dakinep5. he has the ss.
Holy Crap, The SS is a great suspension. Un-real. Have a look at the attachment... Do not install this piece, it will click and break off. Untill it does, every bump you hit will make a noise..
How much for the basic version?
i was told about $1000 shipped to hawaii new, but again, shipping to hawaii is very high. so i would assume $900 for you?
peace
if you're gonna git the TEINs, get the SS. Also, save up some more and get the AWR rear sway bar.
like Brian says, you'll need Impact tools and an extra set of hands.
you will have to remove the brake caliper to install the rear left assembly.
Isn't it come with top mount? Have to use the stock top mount?
Brian MP5T said:
You have to assemble the kit...
The Upper mount is re-used from the stock setup...
It has the alumininum piece you see in the picture, but it uses the top part of the Stock Suspension. You have to get JIC-FLT-A2 to get Camber Plates. Good Luck $$$
Auto Rage said:
we sell tein at good pricing let us know if you want to order.
www.autorage.net
770.461.9449
you are not an Authorized Vendor
pm Antoine about this if you want to promote your website (cool)
